Test Cases for flow only useble for pyStartCase flows?
I`m trying to get used to Pega Testing features, and trying using Test Case on flows as well.
As far as i get i understand that Test Cases for flow could be created only when "Created a new work object" on Process tab of flow is checked. But the only rules that seems to have it checked is the flows that the Case start with, like pyStartCase. For any others flow this option is always unchecked and never editable. Is there anyway possible to check it on flow used in mid of case?
Also, unlike test cases for Activity, i couldn`t find anyway to pre-initilize clipboard for flow Test Cases. If i`m creating Test Case for flow in sub-case i might want to have test parent-case info in clipboard before actually running it
Thx in advance
