Table width does not change more than 1020 if Freeze header is used
We have a table with 20 columns retrieved from an external system for a case, the customer need all the 20 columns, in which few are editable.
Also the data retrieved are more than 20 records so when the user scrols down they need the header to be freeze. Since the columns are more I try to increase the width but still the width in the screen does not change more than 1020. Also when the browser size is reduced to 60-70% the table size does not change.
I have tried changing the width with all width content type but the result is the same.
Is there any other solution for this?
