Tech Mahindra Ltd
Last activity: 28 Nov 2019 7:58 EST
How to Freeze Header and First Column for Repeating Grid without freezing grid width and height
Requirement:
- 1) We need to Freeze Repeating Grid -> Header and First Column.
- 2) Grid Width and Height should be flexible/responsive and should not be fixed (should auto fit based on screen resolution).
- 3) Sort and Filter functions should work.
In Layout Properties -> Presentation, I have given "Grid size" fixed width and height and checked "Freeze grid header & Freeze column pane" options(Attached Screenshot), But I need flexible grid/Responsive grid i.e, Grid width should get Auto-adjusted(100%) with resolution. And also, in this case, the other issue I see is Grid vertical scroll bar is not working with Mouse wheel action.
Please advice and let me know what is the best way to fulfil requirement.
you can get this by using the option "Freeze column pane" along with freeze grid header.
This option is avialable with pixelfixed grid.
See the attachement for more clarity.
