System Runtime Context is not picking the new Application Rulesets
I have added my application to the System Runtime Context but rulesets are not showing up in Resolved rulesets
***Edited by Moderator Marissa to add Capability tags***
Could you please add the application along with the correct version in the system run-time context rule and click on the save which is there on the right top. Then click on the resolved rules where you see the updated rulesets.
I am also facing the same issue. The required application and version is also added in the system runtime context but the correct ruleset is not appearing in the resolved rulesets. Also at runtime my changes are not getting picked from the desired ruleset.
I am also facing the same issue, the highest ruleset is not showing in the resolved ruleset though the highest application has been added in the system runtime context. Any luck on this issue?
