TATA Consultancy Services Ltd
Last activity: 12 Jan 2017 12:06 EST
System Architect Essentials I (7.1) PVS exercise system does not run Using VMware Workstation Player
System Architect Essentials I (7.1) PVS exercise system does not run Using VMware Workstation Player.The .ova file is imported and played succesfully on VMware Workstation Player and shows the message "Pega 7 Exercise VM started on ......" but the URL to enter into the Pega 7 shows only http://:9080.
I tried with the url http:// Proprietary information hidden:9080 after finding the ip using ifconfig command on the VMware Workstation Player window.but cannot be accessed.
When I shut down the VMware Workstation Player through "Shutdown guest" option I noticed that "PostgreSQL" DB is shutting down message.Please help.
***Updated by Moderator: Lochan. Removed user added Ask the Expert and helpme tags. Apologies for confusion, shouldn't have been an end-user option***
Hi Dhritman,
I think I got your problem. its because of no IP assigned to eth0 of your VM.This you can verify by typing the command "ip addr show eth0".
Please follow the below steps.
Step 1: In VMWare Player's main window, go to the settings tab.
Step 2: In the settings window, click on "Network Adapter" and among the options on the right, select "Host-only: a private network shared with the host". Please find the screenshot below :
Hi Dhritman,
Step 3: click ok.
Step 4: Boot your virtual machine.
Step 5: If you have access to the linux command prompt, assign the ip address Proprietary information hidden like this (if you have root access):
ifconfig eth0 Proprietary information hidden netmask Proprietary information hidden
or Step 5b: sudo ifconfig eth0 Proprietary information hidden netmask Proprietary information hidden (if you don't have root access).
Please not that you can use any other address also but in the format <192.168.x.x>
Step 6: open the start menu and launch "Command Prompt". You find it in All Programs -> Accessories.
Step 7: Inside the command prompt, type ipconfig /all and press enter. One of the lines should display something like this:
for me its like below:
Step 8: With the VM running, switch back to Windows and from the command prompt you opened in Step 6, type ping Proprietary information hidden
You should get an output pretty much like this(for me its like):
And most probably now you will be able to hit the URL.
Hope this will help you.
Also find below some links , from where I collected these information:
http://askubuntu.com/questions/497850/eth0-no-carrier-ifconfig-shows-no-ip-address
http://unix.stackexchange.com/questions/160312/ip-address-not-populating-in-eth0-in-ifconfig
Please let me know on the further concerns and also confirm whether it helped you or not. Also if it doesn't solve your problem please raise the query in Pega Academy Community forum.
Thank you
Ai4Process
Hi please contact [email protected]
Damien
Can you try with Oracle VM Virtual Box (https://www.virtualbox.org/)
Thanks Ashutosh for your reply.I have already installed VMware Workstation Player, now installing Oracle VM will hamper anything,as I am using VMware Workstation Player for PRPC 6.2 SP2.Can you please guide me how to download and intall it.
Hi Dhritman,
Supporting Ashutosh , please try with Oracle VM Virtual Box because now a days Pega Acdemy VM is compatible with Oracle VM. Even I faced the same issue when not using Oracle VM.
Also have you tried with "localhost" or "prpc.local "instead of ip adress.
Thankyou
Thanks Abhishek for your reply.I tried localhost and only prpc. but it did not work.I will try again with "prpc.local ".I have already installed VMware Workstation Player, now installing Oracle VM will hamper anything,as I am using VMware Workstation Player for PRPC 6.2 SP2.
Hi Dhritman,
I don't think it will hamper any thing. You can keep both VM and use accordingly.
Even I am using 2 both VMs in my system.
Thankyou
I have attached the guide for the VM. Pleas refer that.
and let us know on the further concern.
Tech Mahindra
It is just two hypervisors (one from VMWare and other from Oracle) you will be running. So there is no harm.
For the prpc.local / localhost / ip address related question... as long as you have the local admin access and have access to change the hosts file entry, you can make entry for the prpc.local pointing to the IP picked up by the VM you are running, you will be able to access the Pega Server just by using the prpc.local. However, at times, if you are running multiple hypervisors hosting different guest OS, they may pick the IP mapped to prpc.local on the hosts file. So do not get bogged if one is working and other not. When you get into such problem, take a look at the hosts file, if you have played with it.
Hi Abhishek,
The guide you sent said to extract the downloaded archive using 7 zip,,but for 7.1 Leavaraging Pega/System Architect Essential 1+2 for Pega 7.1,pls note 7.1, offers download exercise system /VM in .OVA file extension.Does it require to extract using 7zip or I just import it using Oracle VM Virtual Box and click the play button?
As per I know , it should be a zipped file which you would have downloaded from the Pega Academy. You need to unzip that as per instruction in the guide.
after installing and running virtual box I am getting below url--http://:9080.When I type the url- http://localhost:9080/prweb/PRServlet or http://prpc.local:9080/prweb/PRServlet I am getting the message--
This site can’t be reached
prpc.local’s server DNS address could not be found.
- Search Google for prpc local 9080 prweb PRServlet
Attach is the screen shot.Please help.I am getting the sane error when running the VMware Workstation Player
Hi Dhritman, from the screenshot attached , it seems that you are not entering the credentials for the prpc credentials.If not Please try with the following credentials:
prpc login: "architect"
password: "password"
And then try hitting the URL. Even try with http://:9080 along with http://localhost:9080 or http://prpc.local:9080 or http://<ip>:9080
You can also check with the 8080 port.
Please let me know on the further concerns.
Not able to login with any url option.Please find the screen shots.I also tried with "http://prpc.:8080/prweb/PRServlet".Other url I used are-1) http://:9080 2) http://localhost:9080/ 3) http://prpc.local:9080/ 4) http://prpc:8080/prweb/PRServlet.5) http://prpc:9080/prweb/PRServlet.6) http://localhost:8080/prweb/PRServlet.7) http://localhost:9080/prweb/PRServlet.8) http:// Proprietary information hidden:9080/prweb/PRServlet.9) http:// Proprietary information hidden:8080/prweb/PRServletI also give the screen shot where I placed the pvs software I downloaded.In the pega provide guide it is stated that I will get the login url from Virtual Box screen itself.But here I am getting only the http://:9080.I am running pvs with VMware Workstation Player for PRPC 6.2 SP2 successfully.
I think the media which you have downloaded is corrupt.
Otherwise ideal login screen is like below with the "ip address for eth0" and its not there in yours :
Have you tried with agin downloading the image and then starting the VM.
Is there any way to download the s/w through ome download accelator?as it is taken too long time 10-12 hours in normal way.
Hi Dhritman,
I am not aware of that.
Other member in the forum can comment.
Thankyou
Hi
I have downloaded the VM for Senior System Architect (7.1) and try to run it using virtual box,but getting the same screen as previous. Not getting the IP address.Pls help,pls help.
Hi Dhritman,
Hi Dhritman,
Step 3: click ok.
Thank you
Thanks Abhishek for your help.I just changed the Network settings of Virtual Box.blow is the screen shot.Now it is working fine.Thanks for your help.
processthreesixty
Clone the virtual machine and check for that.
