CVS Health
Last activity: 15 May 2020 16:36 EDT
Switch of Acces Group from a Service Package rule used by multiple applications in a cluster environment
Hi ,
We have our Pega V722 implementation running in a cluster environment and we have 2 separate applications running from the same cluster. Both apps have controlled by separate access groups. For now, we have DocuSign integration implemented in one application and would like to extend the same to other application by using the reusability of code. As a part of this process, we got stuck in the Service Package given by Pega and is used to listen the DocuSign service events based on the work object handle to process the logic in the sys. Now the problem is we want to switch the access grp and use it dynamically to call the right application specific rules from the REST service activity accordingly. I checked the PDN and I did find few articles but they are not very clear on how to switch the AG on fly. Here is one good article with the java code but no luck from my side.
Attached the screenshot for more info on what I am looking for.
I need some help from the experts in the community to address the issue and find the solution.
Ravi Kumar Pisupati.
