Stream Response Size (PEGA0029)
Getting below critical alert in alert log file.
Stream exceeded client response byte threshold (pxObjClass=Rule-Obj-XML;pyStreamName=GetObjectDecryptedBody;pyXMLType=MapFrom;).
PAL Data :
pxRDBIOElapsed=0.00;pxConnectElapsed=0.35;pxInteractions=1;pxRuleCount=5;pxRDBIOCount=1;pxRunStreamCount=1;pxInputBytes=172;pxTotalReqCPU=0.10;pxRunModelCount=4;pxConnectCount=1;
pxRulesUsed=137;pxRunWhenCount=3;pxRulesExecuted=15;pxOtherCount=5;pxRuleFromCacheCount=5;pxOtherIOElapsed=0.00;xTrackedPropertyChangesCount=4;pxDBInputBytes=2,990;pxTotalReqTime=0.37;
pxActivityCount=9;pxOtherIOCount=1;pxAlertCount=1;pxOtherFromCacheCount=9;
Alert is generating while system is reading the attachment from external system by making the web service call.
Seems ,if attachment size > 200 KB then alert is being generated from response XML steam rule . Please correct me if understand is wrong.
To avoid this alert , we are planning to update the following environment variable.
prconfig/alerts/clientbytesreturned/threshold/default 204800 ----Default .
Is it suggestible to update variable ? Please let me know if we any consequence by increasing threshold value to 10 MB.
