Stream nodes replication factor is failing
We are seeing consistent issue under replication factor (PFA screenshot) for our stream nodes.
Could you please let us know what Keyspace Pega uses for Stream nodes?
As per our understanding Pega 8.x has Kafka enabled as default, in this case what's the keyspace used by Kafka stream?
Will Kafka and other streams use the same keyspace? If yes, How to disable Kafka?
Habeeb Baig
