Fails to start up nodes for stream
I am currently installing Pega 8.2.2 on WebLogic 12c and Oracle DB 12c. It is consisted of 2 nodes.
My first concern was that the search index was not created by clicking the "re-index" button, and figured out that I need to turn on stream service. In order to do so, I had to change prconfig setting to include what's written in the article here.
I thought I was able to solve this by adding these setting to prconfig.xml, however even though port 9999 availability was solved, it seems like there is another port availability issue. Whenever I go to Configure -> Decision -> Infrastructure -> Service -> Stream and try to "start" the node, it ends up in the status "JOINING_FAILED".
I get following error.
org.jboss.netty.channel.ChannelException: Failed to bind to: / Proprietary information hidden:7003
at org.jboss.netty.bootstrap.ServerBootstrap.bind(ServerBootstrap.java:272)
at com.pega.dsm.dnode.impl.server.web.StreamDataSetWebService.run(StreamDataSetWebService.java:95)
at com.pega.dsm.dnode.api.server.StreamServerService.startWebService(StreamServerService.java:631)
at com.pega.dsm.dnode.api.server.StreamServerService.access$600(StreamServerService.java:92)
at com.pega.dsm.dnode.api.server.StreamServerService$StreamServiceStartOperation$2.emit(StreamServerService.java:564)
at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:338)
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:40)
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.await(DataObservableImpl.java:102)
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.await(DataObservableImpl.java:91)
at com.pega.dsm.dnode.api.prpc.service.operation.StartOperation.doActualServerStart(StartOperation.java:175)
at com.pega.dsm.dnode.api.prpc.service.operation.StartOperation.access$400(StartOperation.java:22)
at com.pega.dsm.dnode.api.prpc.service.operation.StartOperation$3.execute(StartOperation.java:156)
at com.pega.dsm.dnode.util.OperationWithLock$LockingOperation.couldAcquireLock(OperationWithLock.java:163)
at com.pega.dsm.dnode.util.OperationWithLock$LockingOperation.performLockOperation(OperationWithLock.java:130)
at com.pega.dsm.dnode.util.OperationWithLock$LockingOperation.access$200(OperationWithLock.java:75)
at com.pega.dsm.dnode.util.OperationWithLock.doWithLock(OperationWithLock.java:72)
at com.pega.dsm.dnode.util.OperationWithLock.doWithLock(OperationWithLock.java:68)
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeWithLockInternal(ServiceHelper.java:212)
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeWithLock(ServiceHelper.java:168)
at com.pega.dsm.dnode.api.prpc.service.operation.StartOperation.initializeServerMode(StartOperation.java:153)
at com.pega.dsm.dnode.api.prpc.service.operation.StartOperation.access$200(StartOperation.java:22)
at com.pega.dsm.dnode.api.prpc.service.operation.StartOperation$1.emit(StartOperation.java:83)
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.toList(DataObservableImpl.java:81)
at com.pega.dsm.dnode.impl.prpc.service.RemoteServiceOperation$ExecuteOperationMessage.call(RemoteServiceOperation.java:112)
at com.pega.dsm.dnode.impl.prpc.service.RemoteServiceOperation$ExecuteOperationMessage.call(RemoteServiceOperation.java:72)
at com.pega.dsm.dnode.api.prpc.service.CallableMessageWithContext$1.run(CallableMessageWithContext.java:33)
at com.pega.dsm.dnode.api.prpc.service.CallableMessageWithContext$1.run(CallableMessageWithContext.java:30)
at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:52)
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContextInternal(ServiceHelper.java:244)
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContext(ServiceHelper.java:103)
at com.pega.dsm.dnode.api.prpc.service.CallableMessageWithContext.call(CallableMessageWithContext.java:30)
at com.pega.dsm.dnode.api.prpc.service.AbstractDsmService.handleMessageInternal(AbstractDsmService.java:261)
at com.pega.dsm.dnode.impl.prpc.service.ServiceDeploymentImpl$PostMessageJobData.handleMessage(ServiceDeploymentImpl.java:589)
at com.pega.dsm.dnode.impl.prpc.service.ServiceDeploymentImpl$PostMessageJob.execute(ServiceDeploymentImpl.java:555)
at com.pega.dsm.dnode.impl.prpc.service.ServiceDeploymentImpl$PostMessageJob.execute(ServiceDeploymentImpl.java:552)
at com.pega.pegarules.cluster.internal.PRPCTask.call(PRPCTask.java:130)
at com.pega.pegarules.cluster.internal.PRPCTask.call(PRPCTask.java:53)
at com.google.common.util.concurrent.TrustedListenableFutureTask$TrustedFutureInterruptibleTask.runInterruptibly(TrustedListenableFutureTask.java:108)
at com.google.common.util.concurrent.InterruptibleTask.run(InterruptibleTask.java:41)
at com.google.common.util.concurrent.TrustedListenableFutureTask.run(TrustedListenableFutureTask.java:77)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:44)
at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:41)
at com.pega.dsm.dnode.impl.prpc.PrpcThreadFactory$PrpcThread.run(PrpcThreadFactory.java:109)
Caused by: java.net.BindException: アドレスは既に使用中です
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Net.java:433)
at sun.nio.ch.Net.bind(Net.java:425)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
at org.jboss.netty.channel.socket.nio.NioServerBoss$RegisterTask.run(NioServerBoss.java:193)
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.processTaskQueue(AbstractNioSelector.java:391)
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:315)
at org.jboss.netty.channel.socket.nio.NioServerBoss.run(NioServerBoss.java:42)
at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
... 6 more
I am took a look at below article and added several other settings to prconfig.xml, but the problem persists.
https://community.pega.com/support/support-articles/hazelcast-uses-wrong-ip
- <env name="identification/cluster/public/address" value=" Proprietary information hidden"/>
- <env name="identification/cluster/protocol" value="Hazelcast" />
- <env name="cluster/Hazelcast/interface" value=" Proprietary information hidden" />
- <env name="cluster/Hazelcast/ports" value="7100-7150" />
- <env name="cluster/Hazelcast/members" value=" Proprietary information hidden" />
- <env name="indexing/distributed/network/host" value=" Proprietary information hidden" />
- <env name="initServices/dnode" value="false" />
Any comments and suggestions would be appreciated.
***Edited by Moderator: Lochan to mask proprietary information***
