Accenture
Last activity: 23 Sep 2016 0:33 EDT
Standards suggestion for a scenario at design level
Suppose i have an abstract class say "A-" and three concrete class "A-B", "A-C" and "A-D"
Now the requirement is on commit of these 3 work object i need to do some processing by running an actity.
Activity has been created in "A-" class.
Now i have a question, in which class declare trigger should be place to run the activity?
Approach 1:
Create one declare trigger in "A-"
Approach 2:
Create three declare trigger in three concrete class.
Which should be the best practice keeping performance factor in mind ?.
~Ross
***Updated by Moderator: Lochan. Removed user added helpme and Ask the Expert tags. Apologies for confusion, shouldn't have been an end-user option***
FR
I think I would use the same approach as the Trigger called pxTrackStatuses which is at Work- level. So I would say A- level, it will also be easiest to maintain.
Hi
For each Declare Trigger rule, the Pega 7 Platform monitors database operations for objects of the Applies To class (and concrete classes derived from that class). So you can keep it in A- level.
Accenture
Thanks Las and Santanu for the reply,
Since "the Pega 7 Platform monitors database operations for objects" creating three triggers would means monitoring three triiger, which would not be advicable from performance perspective, right ?
Accenture
Actually i wanted to list down the demerits of creating declare triggers in three class.
One obvious one is that if a new class A-E comes then we have to create another declare trigger in A-E class.
As asked in the last reply, will creating declare trigger in three concrete class affects performance ?
Accenture
Any Suggestion or updates on this ?
Accenture
Accenture
Any comments / discussion regading the performance aspects of the above scenario ?
Or Is just a matter of choice ??
Hi
As I said earlier, for each Declare Trigger rule, the Pega 7 Platform monitors database operations for objects of the Applies To class (and concrete classes derived from that class). So you can keep it in A- level. Why you have to crate three triggers ?
Accenture
It has been suggested to me that keeping it at child class, wil boost the performance.
So was trying to understand the performance aspects of bothe approach
So that i can have the pros and cons of both the approach
~Ross
