SSO weblogic container auth having issues
We are trying to implement SSO using weblogic container authentication, using Pega 8.6, weblogic 12c. But we are getting below exception from weblogic node logs.
<BEA-000000> <catch exception while parsing principal name from the SPNEGO token.
java.lang.ClassCastException: org.bouncycastle.asn1.DLApplicationSpecific cannot be cast to org.bouncycastle.asn1.DERApplicationSpecific
Kindly update if you have any insights on this issue, thanks in advance.
@ChrisKoyl
