SSO configuration with Microsoft azure not working seeing 403 error
Seeing 403 error in network trace which using sso authentication in pega 8.6.1.
@MaruthiK Can you try the request with CURL and see if its happening. Try with various browsers and also raise an SR with Pega. You should look at the headers coming through.
