Service REST make path param optional
Hi!!
I have the following concern regarding Service REST for v8.3. I am trying to use just one endpoint to be reusable for different methods: POST, PATCH, … in order to maintain just one service rule.
As a requirement, for POST method it is not required any parameter. However for the rest of the methods it is.
I am using as path param the caseID. So the issue is that if I create an endpoint like this:
https://hostname/ServicePackageName/v1/case/{caseID}
POST method is not working if I do the request without the path parameter, for example: https://hostname/ServicePackageName/v1/case
because I can see that caseID path parameter is required, is it possible to make this path param NOT required?
Note: to be compliant with client requirements it is not possible to use query parameters.
