Part of resource param ignored in REST service
In the REST service, defined key as resource parameter.
When I hit the service url http://{ip}/prweb/PRRestService/{SvcPkg}/v1/{Svc}/{key} the TimeStamp in the key is being ignored.
Tried with query params in GET method as well, same issue.
Note: the key here is Rule pzInsKey which has timestamp with # prefixed to it
Any workaround for this?
Could you attach screenshots of your rest service configuration plus an example of url you're trying to trigger?
