SendEmailNotification fails when called from job scheduler
SendEmailNotification fails when called from job scheduler but the same working fine while executing the activity manually. Also, the Job running fine and didn't throw any error in Dev environment. Issue facing in Pre-prod only. Below is the error message got from the tracer. Caught unhandled exception : Unable to send email due to : Couldn't connect to host, port: localhost, 25; timeout 60000
***Edited by Moderator Marissa to update Content Type from Discussion to Question; update capability tags***
