Select a default tab using Openspan
Hi Team,
How to select a tab within Tabstrip control by its Index. I tried with "SelectTab" method of Tabstrip, it works only when we use tab name and not with Index.
The problem is my tab name will have count of the Grid as well, for example, Tab1(2), Tab2(5)........., So unable to use it dynamically.
Arun
You should be able to set the SelectedIndex property.
