Segment running manually is running and failing with time out
Greetings. Hope you are doing well! I am trying to run a segment manually from a population base of 15M, it says Segment is running but i do not see any item queued in System-Queue-DeferredSegments and says segment is running but failing with time out. Is there anything i can check to verify where the issue is?
Bharat
