PT Bank Sinarmas
ID
Last activity: 9 Feb 2018 16:17 EST
Security issue when publish on internet
I have plan to publish Pega System in the internet connection, is there any security issue about this ?
Because i have try to change pega url with xss scripting, it's showing like in attachment ?
How can I solve that ?
Brgds,
Dendi
***Moderator Edit: Vidyaranjan | Updated SR details***
How you are publishing using Pega DWA?
PT Bank Sinarmas
ID
Hi Naras,
What's mean Pega DWA ?
Brgds,
Dendi A
JPMorgan Chase & Company
Pega DWA is Direct web access, you can refer below help document.
https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
The easiest way to avoid this is to only use autogenerated UI rules.If you must use a nonautogenerated rule, always ensure the value has been properly filtered and escaped before displaying it back to the user.
PT Bank Sinarmas
ID
My plan is only open internet connection to Pega Application Server.
And when user want to access the application, he/she must be login using default pega system login form.
Is there additional action to do in Pega System when publish to internet for this security issue ?
Brgds,
Dendi A
In that case we can go for IAC which is secure.
PT Bank Sinarmas
ID
Hi Narasimha,
What's mean IAC & how to apply ?
Brgds,
Dendi
IAC stands for Internet Application Composer.
I think you can go through the below links for better understanding.
https://pdn.pega.com/deploying-internet-application-composer-iac-intranet
https://pdn.pega.com/configuring-pega-web-mashup-authentication-composite-application
Rachit
Hi Dendi,
For the original issue, please refer to the following article:
https://docs-previous.pega.com/secu0005-alert-thread-name-url-contains-invalid-characters
Hi Dendi,
You would need to set <env name="initialization/ErrorOnInvalidThreadName" value="true" />
Updated: 29 Nov 2017 10:33 EST
PT Bank Sinarmas
ID
Already added, but xss scripting still running.
See attachment video.
Brgds,
Dendi A
Hi Dendi,
Please open up an SR so the issue can investigated. Once you do, please add the SR # to the post here.
Thanks!
PT Bank Sinarmas
ID
Hi Brad,
Ok, already open SR with no. SR-B94978.
Thanks.
Hi
You can try giving the following DSS setting.
Pega-Engine - prconfig/initialization/erroroninvalidthreadname/default -> true
Pega-Engine - Security/CSRF/secureall -> true
Pega-Engine - Security/CSRF/mitigation -> True
Thank you
Anuj
Hi Dendi,
What application server/version and browser are you making use of?
Upon reviewing the associated SR, I see that the resolution was as follows. Please do this if you are having the same trouble:
Add below DSS in Designer Studio and prconfig.xml.
DSS:
Pega-Engine: Security/CSRF/secureall = true
Pega-Engine: Security/CSRF/mitigation = true
Prconfig.xml:
< env name="security/urlaccessmode" value="deny" />
< env name="initialization/ErrorOnInvalidThreadName" value="true" />
A server restart is required after making these changes
