Bankofamerica
RuntimeHost.TerminateRuntime is not working
Hi Guys,
I want to close the application and OpenSpan Runtime.So i was using RuntimeHost.TerminateRuntime. But after update of pega Robotics studio 8.0,1056.0. RuntimeHost.TerminateRuntime is not working.
Please help me.
Thanks!!
Accenture
DE
It was working in versions older to 1044 i believe... whenever we called that function runtime would automatically exit by itself... it is same functionality as right click on the runtimeicon in taskbar and click exit ( but through code)
Allied Solutions
You'll have to add an event block or some type of prerequisite logic to call the method. Judging from your screenshot, there is nothing happening in the automation page to trigger the method.
Accenture
DE
Even i am getting the same problem. i think its a bug. please raise an SR. i ma using 8.0.1058
What was the previous version that you were on where it was working? Also can you explain what the behavior was before and after?
Accenture
DE
Karthik Reddy Vangimalla
Try making the link asynchronous - does that change the behavior?
I am still trying to understand what the behavior is, since you have said it is 'not working' ... does the automation continue afterwards? does runtime hang? does the automation just stop?
Bankofamerica
@vegam
RuntimeHost.TerminateRutime - use this to unload the project and close openspan runtime
Ans: yes, automation continue afterwards, Only terminate runtime method is not working.
Accenture
DE
Does making the link asynchronous change the behavior?
Accenture
DE
Hi Vegam,
Thanks for the response
Yes making it asynchronous does work. However it used to work with synchronous link also earlier.
Guangri Liang
Ok great. I will make the team aware of this issue but in the meantime, the solution will be to make link asynchronous.
Bankofamerica
sorry for the late response..
I don't know how to asynchronous the link. can u please help me with any diagram.
Westpac Banking Corporation
Right click on the event link (yellow line) and click on asynchronous. Now, it is dotted line.
Bankofamerica
Thanks Jayachandrak, it is working now.
Bank of America
Hi Mitchell & Team,
I have attempted to use asynchronous option to terminate the process, but its still process is running. Could you please advise me on this
