Rule Compilation Error
We are facing compilation error while save As base version to next Ruleset version using circumstance rule.
Rule is not picked up from the branch while creating the work objects , but if we removed that rule from branch its showing base version .
ailed to compile rule: /com/pegarules/generated/html_section/ra_stream_casesummary_fc6b8e93bcb1815c594c3037234bda6d.java
2025-10-08 15:37:36,514 [tp-nio2-8080-exec-20] [TABTHREAD1] [                    ] [omerSupport:01.01.01] (ernal.cache.AssemblerFunctions) ERROR connct-pega-dt1.pega.net| Proprietary information hidden HA1T68MC12BUNXTOVZ5TYD8B8DOUOJ9BLA kumar.anup - The rule which attempted to use a non-accessible jar during rule compilation is: "com.pegarules.generated.html_section.ra_stream_casesummary_fc6b8e93bcb1815c594c3037234bda6d". Please see error above for non-accessible jar information.
2025-10-08 15:37:36,518 [tp-nio2-8080-exec-20] [TABTHREAD1] [                    ] [omerSupport:01.01.01] (pcentric.RACacheAppCentricImpl) ERROR connct-pega-dt1.pega.net| Proprietary information hidden HA1T68MC12BUNXTOVZ5TYD8B8DOUOJ9BLA kumar.anup - Failed to generate com.pegarules.generated.html_section.ra_stream_casesummary_fc6b8e93bcb1815c594c3037234bda6d
2025-10-08 15:37:36,520 [tp-nio2-8080-exec-20] [TABTHREAD1] [                    ] [omerSupport:01.01.01] (pcentric.RACacheAppCentricImpl) ERROR connct-pega-dt1.pega.net| Proprietary information hidden HA1T68MC12BUNXTOVZ5TYD8B8DOUOJ9BLA kumar.anup - Failed to generate com.pegarules.generated.html_section.ra_stream_casesummary_fc6b8e93bcb1815c594c3037234bda6d
2025-10-08 15:37:48,993 [tp-nio2-8080-exec-26] [TABTHREAD1] [                    ] [omerSupport:01.01.01] (      pega.jsr199.Jsr199Bridge) ERROR connct-pega-dt1.pega.net| Proprietary information hidden HA1T68MC12BUNXTOVZ5TYD8B8DOUOJ9BLA kumar.anup - Failed to compile rule: /com/pegarules/generated/html_section/ra_stream_casesummary_fc6b8e93bcb1815c594c3037234bda6d.java
2025-10-08 15:37:49,127 [tp-nio2-8080-exec-26] [TABTHREAD1] [                    ] [omerSupport:01.01.01] (ernal.cache.AssemblerFunctions) ERROR connct-pega-dt1.pega.net| Proprietary information hidden HA1T68MC12BUNXTOVZ5TYD8B8DOUOJ9BLA kumar.anup - The rule which attempted to use a non-accessible jar during rule compilation is: "com.pegarules.generated.html_section.ra_stream_casesummary_fc6b8e93bcb1815c594c3037234bda6d". Please see error above for non-accessible jar information.
2025-10-08 15:37:49,128 [tp-nio2-8080-exec-26] [TABTHREAD1] [                    ] [omerSupport:01.01.01] (pcentric.RACacheAppCentricImpl) ERROR connct-pega-dt1.pega.net| Proprietary information hidden HA1T68MC12BUNXTOVZ5TYD8B8DOUOJ9BLA kumar.anup - Failed to generate com.pegarules.generated.html_section.ra_stream_casesummary_fc6b8e93bcb1815c594c3037234bda6d
2025-10-08 15:37:49,129 [tp-nio2-8080-exec-26] [TABTHREAD1] [                    ] [omerSupport:01.01.01] (pcentric.RACacheAppCentricImpl) ERROR connct-pega-dt1.pega.net| Proprietary information hidden HA1T68MC12BUNXTOVZ5TYD8B8DOUOJ9BLA kumar.anup - Failed to generate com.pegarules.generated.html_section.ra_stream_casesummary_fc6b8e93bcb1815c594c3037234bda6d
2025-10-08 15:38:20,035 [ttp-nio2-8080-exec-8] [UserPortal] [                    ] [omerSupport:01.01.01] (al.mgmt.GeneratedMethodRuntime) ERROR connct-pega-dt1.pega.net| Proprietary information hidden HA1T68MC12BUNXTOVZ5TYD8B8DOUOJ9BLA kumar.anup - java.lang.reflect.InvocationTargetException
