Rule base Compare Tool Set up
we have requisite to compare rules in the product across different environments. So, i am trying to set up Rule base compare in our dev environment. however, i received below error while trying to set up .
So, Please let me know your inputs on this to resolve this issue and set up the Rule base compare tool successfully.
I attached the screenshot and entered values as accordingly. i looked into the PDN article  for below error and it was susggested to set up
"Make the following change to the operating environment: Enable TLS" , could you please let me know inputs on this.
- Label:Failed to connect, please verify connection parameters, username and password. Cause: (** SOAP service failed)
