- Get Help
Back to top
Back to top
Related content:
Access Deny rules vs Access of Role to Object rules
Application Settings - access from rules
Unathenticated rule set inheritance
OOTB Access When Rules
DSS Variables (Purpose and Rule-set)
When the access group is set to "USER," the accessibility tool fails to work in the Portal
Can Access Deny rules ensure that access is denied across roles in an Access Group?
Unable to read/Access the token to set the operatorid to login
Rule Set Security SLA UI Validation and its rules Rule Resolution
Never used it, but here is my explanation.
Let's say you need to provide access to a particular area in your application based on the number of years of experience.
So Manager's need 5 Years of experience to access that feature in application while User's will need 8 Years of Experience to access that feature.
Now a Manager has below Access Role
App:Manager
And User have following AccessRole
App:User
And Admin has following Access Roles
App:User
App:Manager
So in this case, you will create a Rule-Access-Setting "Experience" and specify in both access roles.
So now at runtime, you can use function getSetting(AppliesTo, SettingName) to get the setting value for logged in operator and control application behavior access.
Also, notice that Multiple settings behavior will be useful for Admin which have both access roles with different settings for Experience, so the largest Experience will be picked, 8 in this case.
App:Manager
App:User
App:User
App:Manager
I know that this example doesn't makes much sense since i just went through the help but should be enough to understand the basics
Also Sort function can be used if Data type is string and you want to sort based on Card Type (Platinum > Gold > Silver)
Let me know if this helps.
