What should be the rule set hierarchy while creating unauthenticated rule set?
Should it be depend on only pega base rule set?
It depends on what you want to do with your ruleset and how you structure your ruleset list. The key thing is every ruleset must have at least a dependent ruleset version, and when you build your ruleset list, it should all end up with the Pega base ruleset.
Thanks Chuat
