RPA and Pega - Pega API Error
We have configured everything as mentioned in the PDN for RPA.
we have configured VM with PEGA for the given work group by running the solution from runtime.
When we route assignments to the robot workbasket through robotworkqueue shape, it's routing correctly. But its unable to invoke the automation.
and in the logs i can see the below error :
ukxxxxxxx0205.xxxxx |Rest|api|v1|assignments|AE3LL8QNNHLG3TYN96MTYUB0VFIPXBZ4K - my step page: {
"pxObjClass":"Pega-API-CaseManagement-Assignment"
,"errors":[
"ID":"Pega_API_023"
,"message":"No assignments are available"
,"pxObjClass":"Pega-API-Error"
and the console logs say : polling for assignments .. No work for robot to pick up.
I am not sure what is the problem here . could you please help me
I faced this issue some time ago, but it turned out that case flow was designed incorrectly. In my case it was not routed to correct workbasket and remained assigned to human operator.
