Tech Mahindra Limited
Posted: Sep 25, 2018
Last activity: Sep 26, 2018
Last activity: 26 Sep 2018 1:43 EDT
Rolling Restart of NBA server nodes on every 15 days/Once in the month for Application maintenance activities.
As a best practices and avoid following issues, we need to reboot all NBA server nodes one by one on every 15 days/ Once in the month for Application maintenance activities.. Could you please provide your view on this. Thanks!
Issue: Following issue will be occurred if we do not reboot server nodes at least 15 days/once in the month.
• Garbage collection is not happens properly hence lot of agents will be stuck
• Sync between server nodes are not happens properly
• Dnode joining failed issue
• Performance issue
• Memory leak issue
• Marketing and decision agents will be stuck
• System Pulse will be always high
• Lot of latency issues in NBA
• Requestor lock exceptions
• Long running sessions
• Wrong rule running and erratic system pulse, for example
System pulse is suspected of not keeping rules synchronized across nodes.
Pulse fails to pick up or apply a rule change on one or more nodes.
Show More
• Performance issue
• Memory leak issue
Rule resolution or rule cache issues appear in a multi-node deployment or on a single node (unknown causes related to system pulse).
• Hung threads
• Thread dumps that can cause system performance issues
• Out of memory errors
• Static content errors
• Failure to regenerate a Rule-Utility-Function (RUF) or Rule-Utility-Library (RUL) after a RAP import
• Looping rules running rampant
• Rule caching issues, for example, a higher version is available, but is not found (development server)
• Static cache issue causing the user interface (images, icons, other elements controlled by the CSS) to not display correctly
Benefits:
• Healthy and Stable NBA environment
• All functionality will be work smoothly
• Prevent Latency/slowness issue
• No data Sync Issues
• Garbage collection working properly
• No Memory leaks
• System Pulse will be always low
• All agents/Listeners will be run properly
• Dnode joining will be always Normal
• Increase performance in Marketing portal and it’s components
• Audience/segments will populate faster
Show Less
