Robotics - Interrogation Matching: Is it possible to use property of a java-element to uniquely identify the object?
Hello everyone
the customer uses Eclipse RCP und LeanFT to start the Java-Application.
The customer Test Management identify the java-elements (objects) using a property called WidgetID from Java Framework.
Does someone know if we could also in Robotic use this property to identify the java-elements?
And if yes, how can we implement this?
Regards Carlos
