Hoverstate
Last activity: 26 Oct 2022 10:08 EDT
Robot Studio fails to open solution after adding reference to Oracle.DataAccess
As title - When I attempt to load the solution after loading this reference it hangs on the "loading project" pop up indefinitely. I must use task manager to close it out. I tried clearing and re-installing oracle, as well as loading a new project and only adding this reference and I still get the error.
The Oracle.DataAccess version I'm loading is Proprietary information hidden
Thank you
@DanQuinlogDoes this library require additional references that might be missing perhaps?
I do not have that library available myself, so I am unable to reproduce this. I would suggest that you open a support request as we'll likely need to collect logs from your machine to determine what the issue might be. If you do open a support request, please report the INC here so we can add any resolution once one is discovered.
