HSBC
Last activity: 27 Jul 2016 23:20 EDT
Restrict Maximum Tabs using Dynamic Container
We are using Pega 7.1.9 with CS 7.1.4 and are displaying the customer interactions in Tabs using the Dynamic Container.
We have utilizing the Multi Document mode with the max documents set to 3. The Problem here is when we set the max documents to 3, at any given point of time 3 tabs are getting launched and Pega is not alerting the user that the maximum document has reached. Also, Pega automatically replaces the third tab automatically when we try to launch the 3rd interaction tab.
There must be an OOTB way of achieving the same functionality, but this is not working as expected.
I have already gone through the below posts where it has been suggested via using a Tab Group and then Dynamic Container, however thats not the case with our implementation. We have dragged a Dynamic Container in a section and then we have included a Harness in the Dynamic Container with Max Documents being set to 3. If the user launches 3 tabs i.e. Home, Tab 1, Tab 2 and then try to click on the button/Link/Grid, it should display a alert message stating "You have reached maximum number of documents" and the processing should halt.
Restrict Maximum Tab in Pega 7.1.8
