BOFA
Last activity: 28 Oct 2018 10:55 EDT
REST Service webmethod
We are trying to connect REST rule using the URL provided by other application and we are getting 403 - the Response data was not recognized as JSON or XML and cannot be loaded.
When we tried SOAP for another webmethod : we get SOAP service Failed. Transport Error: 403 Error: Forbidden
any suggestion?
British Telecom
It would be always helpful to provide the complete stack trace of error/logs to find the exact root cause.
In the logs do you have something like Caused by: com.pega.apache.axis2.AxisFault: Transport error: 403 Error: Forbidden ?
Generally If we dont have permission to access the sever we get this 403 error code.
It would be difficult to tell the root cause without complete error stack trace.
Meanwhile you can have look at below links which may helpful.
https://community.pega.com/support/support-articles/error-parsing-rest-response
https://community.pega.com/support/support-articles/connect-rest-fails-test-successfully
https://collaborate.pega.com/question/unable-send-response-json-rest-services
The error is very vague unless you provide the logs or stack trace but it looks like it is pretty much an authorization issue. Try providing a valid username and password with the right access permissions to invoke the service.
Lesya Stienen
BOFA
log is below
BOFA
com.pega.pegarules.pub.services.RemoteApplicationException: SOAP service failed
at com.pegarules.generated.activity.ra_action_invokeaxis2_74f020aaf2c0d33e9b5acfb21b294798.step16_circum0(ra_action_invokeaxis2_74f020aaf2c0d33e9b5acfb21b294798.java:3647) ~[?:?]
at com.pegarules.generated.activity.ra_action_invokeaxis2_74f020aaf2c0d33e9b5acfb21b294798.perform(ra_action_invokeaxis2_74f020aaf2c0d33e9b5acfb21b294798.java:309) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3597) ~[prprivate.jar:?]
at com.pegarules.generated.activity.ra_action_invoke_0cfba5258feb98ffba5cfba243966b7a.step8_circum0(ra_action_invoke_0cfba5258feb98ffba5cfba243966b7a.java:1025) ~[?:?]
at com.pegarules.generated.activity.ra_action_invoke_0cfba5258feb98ffba5cfba243966b7a.perform(ra_action_invoke_0cfba5258feb98ffba5cfba243966b7a.java:190) ~[?:?]
at com.pegarules.generated.activity.ra_action_pxcallconnector_dcec11a4b9b06b3643e865cea6bb3874.step14_circum0(ra_action_pxcallconnector_dcec11a4b9b06b3643e865cea6bb3874.java:2325) ~[?:?]
at com.pegarules.generated.activity.ra_action_pxcallconnector_dcec11a4b9b06b3643e865cea6bb3874.perform(ra_action_pxcallconnector_dcec11a4b9b06b3643e865cea6bb3874.java:329) ~[?:?]
at com.pega.pegarules.exec.internal.declare.infengine.pages.DeclarativePageDirectoryImpl.runRule(DeclarativePageDirectoryImpl.java:1092) ~[prprivate.jar:?]
at com.pega.pegarules.exec.internal.declare.infengine.pages.DeclarativePageDirectoryImpl.runLoadActivity(DeclarativePageDirectoryImpl.java:446) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.base.handler.ReadOnlyDataPageHandler.loadDataPage(ReadOnlyDataPageHandler.java:241) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.base.handler.ReadOnlyDataPageHandler.findDataPage(ReadOnlyDataPageHandler.java:423) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.base.AbstractPageDirectory.findDataPageInCurrentDir(AbstractPageDirectory.java:941) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getDataPageByInsKey(ThreadPageDir.java:755) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.getDataPageByInsKey(PRThreadImpl.java:2309) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.Executable.findDataPageByInsKey(Executable.java:11015) ~[prprivate.jar:?]
at com.pegarules.generated.activity.ra_action_pyrunrecordexecute_932948a22903e85292f7fad26db0c420.step3_circum0(ra_action_pyrunrecordexecute_932948a22903e85292f7fad26db0c420.java:388) ~[?:?]
at com.pegarules.generated.activity.ra_action_pyrunrecordexecute_932948a22903e85292f7fad26db0c420.perform(ra_action_pyrunrecordexecute_932948a22903e85292f7fad26db0c420.java:109) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10845) ~[prprivate.jar:?]
at com.pegarules.generated.activity.ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.step11_circum0(ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.java:1027) ~[?:?]
at com.pegarules.generated.activity.ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.perform(ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.java:246) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:481) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3414) ~[prprivate.jar:?]
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:399) ~[prenginext.jar:?]
at sun.reflect.GeneratedMethodAccessor97.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55) ~[?:1.8.0]
at java.lang.reflect.Method.invoke(Method.java:508) ~[?:1.8.0]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1338) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1075) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:930) ~[prprivate.jar:?]
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:336) ~[prenginext.jar:?]
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:854) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:331) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:274) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225) ~[prprivate.jar:?]
at sun.reflect.GeneratedMethodAccessor78.invoke(Unknown Source) ~[?:?]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370) ~[prbootstrap-7.3.0-77.jar:7.3.0-77]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411) ~[prbootstrap-7.3.0-77.jar:7.3.0-77]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224) ~[prbootstrap-api-7.3.0-77.jar:7.3.0-77]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:246) ~[prbootstrap-api-7.3.0-77.jar:7.3.0-77]
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168) ~[prbeans.jar:7.3.0-77]
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source) ~[prbeans.jar:7.3.0-77]
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278) ~[prpublic.jar:?]
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223) ~[prpublic.jar:?]
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:678) ~[prwebj2ee.jar:?]
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:394) ~[prwebj2ee.jar:?]
at sun.reflect.GeneratedMethodAccessor95.invoke(Unknown Source) ~[?:?]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273) ~[prbootstrap-api-7.3.0-77.jar:7.3.0-77]
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121) ~[prbootstrap-api-7.3.0-77.jar:7.3.0-77]
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet(WebStandardBoot.java:92) ~[prbootstrap-api-7.3.0-77.jar:7.3.0-77]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[javax.j2ee.servlet.jar:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[javax.j2ee.servlet.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1235) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:779) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:478) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1124) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:82) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:963) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:382) ~[com.ibm.ws.webcontainer.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:465) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:532) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:318) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:88) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.ssl.channel.impl.SSLReadServiceContext$SSLReadCompletedCallback.complete(SSLReadServiceContext.java:1820) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905) ~[com.ibm.ws.runtime.jar:?]
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1909) ~[com.ibm.ws.runtime.jar:?]
at com.pega.apache.axis2.transport.http.HTTPSender.handleResponse(HTTPSender.java:309) ~[praxis2-1.6.2-1.jar:?]
at com.pega.apache.axis2.transport.http.HTTPSender.sendViaPost(HTTPSender.java:194) ~[praxis2-1.6.2-1.jar:?]
at com.pega.apache.axis2.transport.http.HTTPSender.send(HTTPSender.java:75) ~[praxis2-1.6.2-1.jar:?]
at com.pega.apache.axis2.transport.http.CommonsHTTPTransportSender.writeMessageWithCommons(CommonsHTTPTransportSender.java:411) ~[praxis2-1.6.2-1.jar:?]
at com.pega.apache.axis2.transport.http.CommonsHTTPTransportSender.invoke(CommonsHTTPTransportSender.java:233) ~[praxis2-1.6.2-1.jar:?]
at com.pega.apache.axis2.engine.AxisEngine.send(AxisEngine.java:445) ~[praxis2-1.6.2-1.jar:?]
at com.pega.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:406) ~[praxis2-1.6.2-1.jar:?]
at com.pega.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java:229) ~[praxis2-1.6.2-1.jar:?]
at com.pega.apache.axis2.client.OperationClient.execute(OperationClient.java:165) ~[praxis2-1.6.2-1.jar:?]
at com.pegarules.generated.activity.ra_action_invokeaxis2_74f020aaf2c0d33e9b5acfb21b294798.step15_circum0(ra_action_invokeaxis2_74f020aaf2c0d33e9b5acfb21b294798.java:3542) ~[?:?]
at com.pegarules.generated.activity.ra_action_invokeaxis2_74f020aaf2c0d33e9b5acfb21b294798.perform(ra_action_invokeaxis2_74f020aaf2c0d33e9b5acfb21b294798.java:292) ~[?:?]
... 83 more
2018-10-15 13:55:35,160 [ WebContainer : 5] [ STANDARD] [ ] [ AOP:01.01.01] ( internal.mgmt.Executable) ERROR - Exception
... 83 more
Updated: 28 Oct 2018 10:54 EDT
British Telecom
Is connect SOAP is configured to call any SSL ?
Could you enable the loggers for invokeaxis2 activity and provide the logs?
Tata Consultancy Services
Below link explains your exception,please revert back to me if you need furthur clarifications.
https://community.pega.com/support/support-articles/soap-service-failure-remoteapplicationexception
