SA
Posted: Aug 14, 2025
Last activity: Aug 17, 2025
Last activity: 17 Aug 2025 22:23 EDT
Required Pega Deployment Manager 4.8.2 API Documentation /api support document
Dear Pega Team,
We required Pega Deployment Manager 4.8.2 API Document (Swagger Document) to understand about API Endpoints of PDM for automation or kindly arrange to provide download link of pega deploymentmanager4.8.2.zip so that inside that we will check Documentation/readme-for-swagger.md file to find API.
In the below , we could able to find option to choose 4.8.2, So kindly consider for this version PDM 4.8.2 help us to get API
@KaraocU17552759
Here’s the quickest way to get Pega Deployment Manager 4.8.2 API docs. In 4.x, the Swagger and endpoint list ship inside the Deployment Manager artifact: open the zip and read Documentation/readme-for-swagger.md for the download path to the Swagger file. If you already have PDM running, you can download the REST API docs directly from the Deployment Manager portal (Download API/Swagger) without hunting in the zip. If you don’t have the 4.8.2 artifact, ask Pega Support for deploymentmanager4.8.2.zip or access the older marketplace package; that zip contains the same docs. After you import or open the Swagger, you’ll see endpoints for pipelines, deployments, approvals, and more, which you can use for automation. If none of the above is available in your environment, you can generate a Swagger spec by calling the REST services and using Pega’s API2Swagger utility, then host it in Swagger UI.
