Sagility
Last activity: 3 Apr 2024 9:29 EDT
Require UI Script for Entering Text into the File Name Text Box & Perform Click on "Ok" Button
I am working on a use case that involves web application - Certain files are to be uploaded into the web application
When Selecting the Browse Button in the Web Application, File Explorer Dialog Box opens up -- Where i need to pass the path of the file in the Text box and then Click the Ok Button
The File Dialog Box Functionalities are not getting interrogated using the Universal Web Adapter
So require UI Script or any other solution for my concern
PEGA Robotics Studio Version used for the Bot Development is 19.1.86
@FarhanA16850378 I would suggest using a later version of Pega Robotics as we have implemented functionality to handle these through interrogation. The build you are using is almost three years old and many new fixes and enhancements have been added to 19.1 since then. If you do plan to update, you should also look into using our latest release of 22.1 as well.
https://docs-previous.pega.com/pega-rpa/automating-dialogs-chrome-and-edge
