Publicis Sapient
Last activity: 28 Feb 2019 9:21 EST
Removing unused tables from rules and data schema post upgrade 6.4 to 7.2.2
During upgrade pegarules was copied to pegadata, but still we can find tables which is mapped to pegadata and pegarules as well. So we need to remove redundant tables. Is it fine to have tables which is present in both the schemas even though it is not mapped to application?
Even though some do not have content in one scheme but in the other, it seems that the definition of the tables must be present in both schemes. If we try to remove them then it gives errors in pega. For example, you would expect the PR4 tables only in pegarules. But there is a routine which is looking for in pegadata.
examples:
PC_INDEX_ACCEL no data most recent DDL in dev PEGARULES
PC_INDEX_FLOWREF no data most recent DDL in dev PEGARULES
PC_INDEX_LOCATION no data most recent DDL in dev PEGARULES
PC_INDEX_WORKPARTY only data in PEGADATA
PR_INDEX_ACCESSGROUPROLES most recent data PEGADATA
PR_INDEX_ACCESSGROUPWKPOOLS most recent data PEGADATA
PR_INDEX_PRIVILEGE different table structure (Last DDL most recent PEGADATA )
PR_LICENSE_PARAMETERS most recent DDL in dev PEGADATA ( in Prod equal )
PR_SYS_STATUSNODES most recent data PEGADATA
PR_SYS_WORKINDEXER_QUEUE mixt image old data in both no data in prod PEGADATA but oldest DDL PEGARULES dev
PR4_HISTORY_RULE only data in PEGADATA
PR4_LOG_RULE_USAGE mixt image recents data in PEGADATA , but most recent DDL Pegarules
PR4_LOG_RULE_USAGE_DETAILS only data in PEGADATA Prod
examples:
PR4_RULE most recent data in PEGARULES
PR4_RULE_AUTOTEST old data most recent DDL in dev Pegadata
PR4_RULE_FILE most recent data PEGARULES
PR4_RULE_FLOW most recent data PEGARULES
PR4_RULE_PROPERTY most recent data PEGARULES
PR4_RULE_SHORTCUT most recent data PROD PEGARULES
So the question is how to remove unused tables ? So that we can improve our performance.
