Remove Required Property Error Message from UI Header
How can I remove the error headers that appear at the top of each layout group (Picture below)?
The properties are set to always required, which is necessary, however the error header which is duplicated eats up UI space.
I've tried toggling the "Keep error display visible" check box in the harness but this has no effect on the headers below.
