Stella
Last activity: 11 May 2019 12:02 EDT
Refer to a data page
I create a page property and set it to refer to a data page and set the data page to load once for each interaction
The class of the page property has 10 properties within it. I reference each of those 10 properties on the UI of my work object. Does this mean the data page will get called 10 times and thus the database that the data page calls will be called 10 times to fetch the same data?
I believe it could depends on your custom configuration. Have you tried to trace it to verify your assumption and current behaviour on your side? which release of the product are you running?
