Reading file from external shared location
I am trying to read file from a shared location. The filepath is a UNC- "\\server\folder\file.xml".
I need to read this in java code.
Our Pega server is installed on linux. So I converted the \ to /.
When I use the PRFile api, and provide filepath as "file://server/folder/file.xml", file.exists() returns false and
file.getAbsolutePath() returns "file://default:/server/folder/file.xml".
Passing fileName without "file://" returns the same thing.
So I tried java.io.File. to this I passed URI(filePath) but I am still getting the same results, absoluteFilePath is /server/folder/file.xml and .exists() returns false.
I can access the files in eclipse on my windows machine with java File class.
Can anyone help with this?
