Capgemini India PVT Ltd
Last activity: 20 Aug 2019 11:08 EDT
Radio Button checked state is not behaving properly when Refresh event is added to the layout only in IE/IE 11
Radio Button checked behavior is not behaving properly when Refresh event is added to the layout only in IE/IE 11
*** For Chrome & Mozilla it is working perfect
Normally the radio button is working fine,but as soon as in the
Section > Layout > Actions ---- When Refresh this section is included the problem is visible,the checked element is jerking or not visible just after click is released.
We Need Refresh this section with radio button working fine like chrome.Can someone assist me with this?
Please find the attached screenshot.
Please refer https://collaborate.pega.com/question/ie11-unable-select-radio-buttons-73 . It seems to be a similar use case.
Laimonas Gelžinis
@@@Rachit_CGS
When the Refresh this action is removed from layout actions ,its working fine.I think the case mentioned by you does not incorporate Event - Refresh this Section.When this particular event is removed its working perfect.
But I am looking for a solution where radio ui in IE 11 will be fine,keeping the Refresh event
Swathi Palagani
Updated: 20 Jun 2018 23:19 EDT
What is the source of Radio buttons? Can you please, for using purpose, try with a local list?
Please provide PRPC version also.
Also, are you using these radio buttons in a GRID?
Cognizant
BE
Yes I am using in grid, facing same issue.
@@@Rachit_CGS
Add a 'post value' action before 'refresh this section' action and give a try.
Coforge Technologies
The jerking behaviour is also observed in 7.2.2 version also using DisplayYesNo Control.
I tried to reproduce the issue in 7.2.2 for DisplayYesNo Control, but it is not reproducible. Would you like to share the steps to reproduce?
