Allianz
DE
Last activity: 12 Feb 2016 9:22 EST
Questions to Admin/pw in SMA
we have installed Pega 7.1.7 and are using the SMA quite frequently. Therefore, we want to create a variety of roles with different access rights as SMA is not secure by default. That being said, I have some questions to the Image depicted below which is part of the Node Configuration in the SMA:
1. What happens when I enter a Username + Passwort? Is it like initially creating an Administrator role and noone has access to the SMA except the admin with the entered credentials?
2. Where is the entered username + Passwort saved? Within PRPC? On the DB?
3. After having created this admin-role, how can I retrieve the password if I loose/forget it?
4. Are there any best practices regarding the roles concept of the SMA? Is it recommended to have only one role (admin)?
Even though I have found a guide how to create roles, those questions are still interesting to me.
Thank you!
Best regards
Thank you!
Best regards
