Credera
Last activity: 22 May 2025 6:27 EDT
Query runner in onprem Oracle Database
Query runner in on-prem Oracle database is not working and throwing below error:
Unable to fetch SELECT query results select * from pc_assign_worklist: code: <none> SQLState: The DataStoreConfiguration was not found for the DB Name "pegadata" as it is not registered in the configuration map Message: <none>
DatabaseException caused by prior exception: com.pega.platform.datastore.ConfigurationException: The DataStoreConfiguration was not found for the DB Name "pegadata" as it is not registered in the configuration map
Pega platform: v8.6.3
Default Schema names PegaRULES and PegaDATA are changed at customer end say xyzRULES and xyzDATA
