Query regarding React Pega - how to pass parameter dynamically in React Pega to external React
I'm trying to do a project in Pega React,
It quite similar to Clock Component, Clock Control in Pega React.
for my project in Pega React, i have create below in Pega Section:
2 components
reactpoc_wrapper js
reactpoc js
and the component - reactpoc js will call external React to load inside the Pega Section.
Now, my next step is need to pass parameter dynamically from this pega react Section to the external React that I call which is reactpoc js.
How should I write to pass parameter dynamically from Pega react Section to the external React ?
Also the Control is reactpoc and code is as below:
2 components
reactpoc_wrapper js
reactpoc js
<pega:choose>
<pega:when test="pxRequestor.pyPegaDesignMode != 'true'">
<!-- only include REACT JS once per page - use the bundle 'pzpega_ui_react_dev' for development and 'pzpega_ui_react' for production -->
<pega:onlyonce name="pega_ui_react">
<pega:static type="script" app="webwb">
<pega:bundle name="pzpega_ui_react" />
</pega:static>
</pega:onlyonce>
<!-- only include this component once per page - will not be reloaded on refresh -->
<pega:onlyonce name="pyReactClock">
<pega:file name="ReactPOC.js"/>
<pega:file name="Reactpoc_wrapper.js"/>
</pega:static>
</pega:onlyonce>
// Gen unique id for element
String uniqueId = "NabXShellWrapper"+Long.toString(((com.pega.pegarules.priv.context.PegaRequestor) tools.getRequestor()).currentTimeUnique());
<div id="<%= uniqueId %>">
</div>
<script>
ReactDOM.render(React.createElement(NabXShellWrapper), document.getElementById("<%= uniqueId %>"));
function receiveMessage(e) {
console.log('receiveMessage', e);
window.addEventListener('message', receiveMessage);
/* Clear the state of the component on an Ajax Reload to set the setInterval ticker by calling the unmountComponentAtNode method function */
pega.u.d.registerAsHarnessElement({
nullify: function() {
ReactDOM.unmountComponentAtNode(document.getElementById("<%= uniqueId %>"));
}, pega.u.d.getSectionDiv(document.getElementById("<%= uniqueId %>")).getAttribute("uniqueID"));
</script>
</pega:when>
<pega:otherwise>
<span>XShell React Component</span>
</pega:otherwise>
</pega:choose>
Thanks.
