pyRequestData Adds extra Quotes making the SERVICE call failed
Hi everyone
I've a Service REST configure to use the POST method, however when I run the DataPage, I receive a "INVALID JSON" error.
Tracing the execution, I see that pyRequestData is adding one extra pair of Quotes to the Request Body:
pyRequestData
And this is how it should be:
I've tested adding the extra set of quotes into Postman, and the API fails with the "INVALID JSON" error that I see on PEGA.
Is there any way to avoid pyRequestData to add those quotes?
@Junicavi It sounds like you are encountering an issue with the JSON formatting in your Service REST configuration. The `pyRequestData` is adding an extra pair of quotes to the request body, which is causing the INVALID JSON error. To resolve this issue, you can follow these steps: 1. **Check the Data Transform**: Ensure that the data transform used to construct the JSON is correctly formatted. Verify that there are no extra quotes or incorrect syntax in the JSON structure. 2. **Modify the Data Page Parameters**: On the Parameters tab of your data page, provide the JSON as an input. Ensure that the JSON is in the correct format that the connector accepts. If necessary, use a data transform to format the JSON correctly. 3. **Use a Custom Data Transform**: If the JSON is not in the format that the connector accepts, you can run the same JSON data transform again in deserialized mode. This will convert the JSON back to a page in the request data transform in the data page. Then, in the request data transform, continue to make the request. 4. **Review the Connector Configuration**: Ensure that the connector configuration does not add any extra quotes or modify the JSON structure. You can do this by checking the request data transform and the connector rule. 5. **Testing with Postman**: Since you have already tested with Postman and confirmed that the extra quotes cause the API to fail, use this information to adjust the JSON formatting in your Pega application.
@Junicavi It sounds like you are encountering an issue with the JSON formatting in your Service REST configuration. The `pyRequestData` is adding an extra pair of quotes to the request body, which is causing the INVALID JSON error. To resolve this issue, you can follow these steps: 1. **Check the Data Transform**: Ensure that the data transform used to construct the JSON is correctly formatted. Verify that there are no extra quotes or incorrect syntax in the JSON structure. 2. **Modify the Data Page Parameters**: On the Parameters tab of your data page, provide the JSON as an input. Ensure that the JSON is in the correct format that the connector accepts. If necessary, use a data transform to format the JSON correctly. 3. **Use a Custom Data Transform**: If the JSON is not in the format that the connector accepts, you can run the same JSON data transform again in deserialized mode. This will convert the JSON back to a page in the request data transform in the data page. Then, in the request data transform, continue to make the request. 4. **Review the Connector Configuration**: Ensure that the connector configuration does not add any extra quotes or modify the JSON structure. You can do this by checking the request data transform and the connector rule. 5. **Testing with Postman**: Since you have already tested with Postman and confirmed that the extra quotes cause the API to fail, use this information to adjust the JSON formatting in your Pega application. By following these steps, you should be able to avoid the extra quotes being added to the request body and resolve the INVALID JSON error.
pyRequestData Param data in Connect-rest
Creating a REST integration by using the Create REST integration wizard]()
JSON data transforms
Service REST rules
