Property not pushed from Decision Data form to Strategy in PEGA 7.1.9
I am new to PEGA Decisioning, and hence apologies if my terminologies are not very accurate.
But we are facing this weird problem:-
Problem Summary:-
1) Within Decisioning -->Proposition Management ,
i) we were initially using the PEGA out of the box the form to fill in the properties. And everything worked fine. ( Refer to screen shot 1)
ii) Then we got a request to add in another 100 properties to the form, so we thought of using the customize form feature to handle visibility of the form in better way. ( #Screenshot 2 & 3)
iii) But when we moved to the customize form, we have observed that the form stores all the information correctly. We verified the same by viewing the XML data of the form. ( Screen shot 4)
But when these propositions are imported in the Strategy using "Proposition Data" component, we cannot see all of the properties of the proposition under the Property section ( as highlighted in screen shot 5). Even though the propositions defined in "Proposition Management" has all the necessary values.
Can you help us out in this case, as to why not all properties are flowing through the Strategy? We have tried to clean the caches of the application by re-starting the application server. But still no use.
***Edited by Maryrita, moderator: moved to Product Support from Applications***
***Moderator Edit: Vidyaranjan | Updated SR number and tagged SR Created***
