Property not matched - try/catch not working
I am having a really hard time figuring out why this is not working properly. I have added a try/catch but I do no think the catch is working properly, it may be the type of exception. I selected openspan->Automation-> invalidLinkException. I have a web adapter that is trying to open a java web application. Before the Java application will open I have to select the Run Button on a pop up. When I run the application locally through studio I do not get the error as often as when I run it through runtime, which appears to be slower. I am first waiting 75 seconds and then checking the Run button properties to see if it is enabled before I perform the click. If not enabled I am looping through every .5 seconds to see if it is enabled. The problem that I am having is no matter what I put in the forLoop I get the same error "btnRunJava is not matched". I am not sure why I would be getting this error. If it were not matched then it should go to false and then eventually the forLoop would timeout correct? I have attached my code and the error, any suggestions would help.
@ZachT124Your automation does not appear to be correct. Perhaps it is just that the image is deleting links, but there appears to be nothing coming off of your Try. The Try Catch really needs to wrap an area of your automation where you wish to catch the exception. I would suggest wrapping as few steps as possible to avoid any confusion. In this case, you are really getting a "ControlNotCreated" exception (at least according to your screenshot). That basically means your control is not matching. You should be able to see in the RuntimeLog all of the attempts at matching (assuming you enable Verbose logging for all categories). I suspect though, that you can identify this in interrogation mode. Do you have any ambiguous matches? Do you need to click Rematch at all during interrogation? Are you certain all controls you expect are matching as expected? I would try to reproduce the issue during interrogation to see what you might need to do to address it.
