properties mapped in service response mapping not sent fully to calling service, due to service called within that DT is failing
we are using service-rest in the service response mapping Data transform, we are setting so many properties, including one service call (connect soap). when the soap service is failing, but the parent service rest is success. The property values which we set in the response mapping DT are not sent to calling application. but in tracer servicepage we are able to see all the properties are set in response page. they why it is not sent to calling application. can you pls help on it. using Pega Infinity '24.2.2
