Product rule class instance filter
What is the correct/recommended way to create a filter on for Class instances in a Product rule as of Pega 8.3.1?
When adding Class instances to a Product rule, there are options to add a ListView filter or a When filter. We have previously used a When filter but now see a guardrail warning stating, "Using when rule filter is deprecated. Instead use list view filter." However, when creating a ListView rule, there is a guardrail stating, "List Views have been deprecated and should be replaced with a combination of Report Definitions, Grids, and Data Pages. List Views are not supported in Microsoft Edge or later browsers."
Same issue mentioned in below link:
https://collaborate.pega.com/question/product-rule-using-when-rule-filter-under-class-instances-include-section
One SR was raised and it was resolved as an enhancement request, FDBK-62491.
It is fixed as a part of Pega 8.4 release. This warning would not result in any performance degradation of the application and it can be safely ignored.
