Procedure Automations return NULL
Hi Everyone,
I'm using Pega Robotics Studio 8.0.1096.0 and same Runtime version.
I have created Robotics solution with many procedure automations with exit string parameters.
When I run the solution it didn't retrieve the data to UI so I debug and found out procedure automations do not return expected value. They return NULL as you can see in "Procedure Return Null.png". But when I run same solution without any modification in friends machine with same version it runs as expected and procedure automation returns values as seen in "Procedure Return Value.jpg"
So there isn't a error in my automation but it with my installed studio and runtime environment.
I need to correct this error without reinstalling studio and runtime.
It was also observed that message manifest don't return values as well.
Please help me to resolve this.
Thanks in advance.
Dilshan
