Pre-defined values of a parameter in the Entry Point
Would like to ask if there is a way to make the parameter of the entry point in an automation to have a pre-defined values in it?
So when this automation is called in another automation, the value of this parameter will just be then selected from those pre-defined values? See image below for an example, on what I want to achieve with my question.
In the image below, I just manually type those 3 options in there but I would like it to be like in a boolean datatype parameter wherein you're just going to select the True or False value in a dropdown?
