The Toronto-Dominion Bank
Last activity: 28 May 2019 4:46 EDT
Platform FixPack versions Compatibility check
Need your help to confirm the Compatibility of Pega CRM 7.22 and Pega 7.2.2 with the below server fix pack versions which are built for our PAT environment below which are different from our BAT environment given below where the Business testing was performed earlier.
Can someone please confirm if the below Websphere/Linux/Java versions for PAT are supported by Pega CRM 7.22 and Pega 7.2.2 or not.
PAT: WebSphere Platform Proprietary information hidden [ND Proprietary information hidden cf131801.05]
BAT: WebSphere Platform Proprietary information hidden [ND Proprietary information hidden cf121726.02]
PAT: Host Operating System is Linux, version 3.10.0-862.9.1.el7.x86_64
BAT: Host Operating System is Linux, version 3.10.0-693.17.1.el7.x86_64
PAT: Java version = 1.8.0_151, Java Runtime Version = Proprietary information hidden - pxa6480sr5fp6-20171124_02(SR5 FP6), Java Compiler = j9jit29
BAT: Java version = 1.8.0, Java Runtime Version = pxa6480sr4fp5-20170421_01 (SR4 FP5), Java Compiler = j9jit28
***Updated by moderator: Lochan to update platform capability***
