  Cognizant Technology Solutions Benelux BV
Last activity: 30 Nov 2020 17:49 EST
#PegaHackathon2020 Mobile build server credentials
Hi ,
I created my application .
However, when I am trying to build the mobile app getting following error message
"CANNOT BUILD APPLICATION. BUILD CONFIGURATION ISSUE Build server account is empty in Admin Studio mobile settings"
If I open the Authentication profile "MobileBuildServerAuthentication" then I see user name as "=D_pzMobileBuildServerAuthentication.pyUserName"
DSS setting of "pega/mobilebuild/baseurl" is https://mobilebuildserver.pega.com/buildserver.
So just want to verify if those details are correct or not.
I am using pega provided environment.
Hi Dipak - I set you up with the pega-trial account for the https://mobilebuildserver.pega.com/buildserver on your system. Let me know if you have any further issues. Good luck!
  Tech Mahindra
Hi Matte,
We are building a Hackathon solution. Is it possible to get the mobile server Credentials in the community edition? Thanks in advance.
Hi Nizam - I updated your Auth Profile to use pega-trial as well.
  Tech Mahindra
Thanks you so much
  Capgemini
Hi Matte,
We are also building a Hackathon solution in community edition. Could you kindly update our system as well to get the mobile server credentials.
Thanks in advance
Hi Vinoth - I added the pega-trial authentication details to your Community Edition trial system.
  Capgemini
Thanks much Matte
  TATA CONSULTANCY SERVICES
Hi Matte,
I am also trying the same to build mobile app. Can you please enable for my system as well.
Hi Anto Sharon - I updated the auth profile with the pega-trial credentials in your Hackathon system.
Thanks a lot Matte.
Hi Matte,
I am unsure of the credentials that I should use to download the app after building it. can you please clarify it.
Hi Anto - There are no special credentials for downloading your app. You can use the Pega Mobile Preview app or just your mobile browser to log into it with any valid operator from your application.
Hai Matte,
I am able to access it with a valid operator. Thanks a lot.
Updated: 30 Nov 2020 10:54 EST
  proess360
Hi Matte,
I'm trying to build mobile application as part of my learning. Can I get the mobile server credentials for trial version please.
Hi Satish - Pega trial mobile build server credentials are included in the Pega platform trial.
  Satish kumar reddy Polireddy
