Pega Survey Best Practise
Hi - Would like to know the best process around using Pega Survey in a client project. From Survey Landing Page you can create a Survey which is an instance of "Rule-PegaQ-Questionnaire" . Ideally as per me it should be an instance of an application specific class which will inherit from "Rule-PegaQ-Questionnaire".Similarly after creating the survey , the sections if that need to be modified to fit into a customer requirement should be modified at application class level only . Would like to know your views and experience on this .
