Pega Smart Investigate - Outgoing XML message via MQ - adding of xml version encoding
Hi all,
would you be able to help me on how to add an encoding to the beginning of a XML message that will be sent via Connect-MQ ?
It should be either of the below added to the start of the message:
<?xml version="1.0" encoding="utf-8"?>
<?xml version="1.0"?>
Hi all,
e.g. the message would look similarly:
<MsgData>
<Header>
<HeaderVersion>2.1</HeaderVersion>
<MessageReference>000001010184749</MessageReference>
<CreationDateTime>2024-07-08T08:07:11Z</CreationDateTime>
<MessageType>pacs.008.001.08</MessageType>
<UsageIdentifier>swift.cbprplus.02</UsageIdentifier>
<AppHeaderType>head.001.001.02</AppHeaderType>
<BulkType>None</BulkType>
<TransmissionParameters>
<Environment>ACC</Environment>
<TransmissionReference>4000164407</TransmissionReference>
<BackEndId>SIMISO-133</BackEndId>
<Direction>ToNetwork</Direction>
<Network>SWIFT</Network> ....
Is this possible?
I was looking into using -Dfile.encoding=UTF-8, however I am not sure how to implement this, whether in the MessageCreator activity or somewhere bit else?
Thank you for any suggestions.
